mini van?
You can always check out your local shop to see what they offer. Or go to a car show or car stereo competition to whats hot.
When it comes to subs and amps, you can get mediocre for $200 or you can get good stuff for $2000+
well, if you're starting from absoultey NOTHING...then 600 to 750 will get you a respectable, all around system. If you already have a headunit, then you can cut that number down to 500~600.
don't always go to a shop man unless you know there work and trust it. because i've known shops that can rip you off or say you need this that when you don't need it at all. example: best buy or circuit city saying you need a Capacitor:rolleyes://content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif. Just do alot of research man read up on here , books , watch friends install etc.....
If you already have a deck then you are in good shape. I don't know what you mean by system though...subs? Just a stereo? All new speakers?
My recommendations:
Start with a deck and new front speakers, those are going to be the ones YOU hear and is what matters most. If you want subs you are looking at minimum 500 installed. A decent deck and two will cost you $300 not including install. You also have to factor what parts you will need to get the deck to fit into the factory location (dash kit, harness, antenna adapater) And that all depends on which kind of vehicle you have. Those parts could run you $40-$250.
I suggest you find a budget or even a used cd player/reciver (called a Head Unit). Don't blow your dudget on this. Ignore claims of "high power".
Pick up a decent 2 channel amp, and wiring kit, and the best 6 1/2" component speakers you can afford. Power the new front speakers off the amp, not the built in amp in the HU. You can use the built-in HU amp to power your rear stock speakers. Read the sticked threads on how to seal and dampen your doors for speaker install. That will get you started in the right track. After you've got that installed you can decide if you want subs. Subwoofer systems can go from low budget to outrageous, and everything inbetween.
david4040
david4040
minneapolis, MN
david4040
