Midbass Mayham
edzy
SPL Ninja
Just arrived.
Thanks. btw, My dogs nose is in pic 2. I just noticed. lol.
Anyway, I may not go with the Diamond amp.
I just came across one of these, and have sights on a second..One for each channel giving each 80 watts. So if I can get another thats the plan, if not, the D3 400
Nakamichi PA301 Monoblock Power Amplifier
"Unlike most mono blocks these are full range amplifiers (most class D mono's are only good for amping up to 250htz). Hence you can run what ever you want from it, subs, components, etc.
160 watts RMS at 4 ohm
240 watts RMS at 2 ohm
THD: 0.005% at rated power
Frequencey response 10-50,000htz
Signal to noise ratio: better than 100dB (IHF A-WTD at rated power)
Damping factor: greater than 1,000
Channel separation: better than 80dB
Power source: 10.8 - 15.6 volts"
edzy
SPL Ninja
edzy
Where you live
jmanpc
Mike Mccabe
