mercedes ml?
ismelllikepoop
Poophead
210
tj
anyone here do any install work on a mb ml? its a 2002 model, and i dont know how to take the door panels off, anyone know where to get this info? Is there a lot of clearance for speakers? also i've been told that dynamatting mercedes's usually is a waste of money since they are built more solidly than other cars. I have a little bit of rattle that I can pinpoint to the arm rest, but beyond that it seems fine, (ie if i put my arm on the arm rest there are no rattles squeaks etc). Any input would be great, thanks!
improve setup, and basically trying to learn how to do stuff myself. The guy at the local shop has been great, but i kind of want to learn to do basic stuff myself. I posted a few things about wanting to change speakers, but everyone says to try and fix the setup first. I don't know where the specific points are to remove the panels on an ml, and dont know if bothering with dynamatting the whole door is worth it (two shops said there might be a little noticeable diff but definitely not worth the cost). if trying to work on the setup doesnt do much, i possibly want try out a different set of comps (dls ms6 to replace kappas)
You probobally don't want to hear this, but '00+ ML's have fiberoptic connections. You will have to rewire the entire truck if you want to upgrade the speakers/amps. If you are still having trouble with the door panels, I can point you to a site with that information //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
ismelllikepoop
Poophead
ismelllikepoop
tj
NYG_84
