specs or amp are as follows. looking for 200$ for the amp OBO and 15"mojo is 300$OBO
1100W RMS Class-D Monoblock Subwoofer Amplifier
Custom Black Pearl Finish
Fully Variable Low-Pass Filter: 50 - 250 Hz, 18 dB/Oct
Variable Subsonic Filter: 20 - 50 Hz
Bass Boost: 0 - 18 dB
Gold-Plated RCA Connectors
4 Gauge Power Wire Capability
Wired Remote Gain Control
Power and Protection LEDs
Thermal, Short Circuit, and Overload Protection
RCA Outputs: 1 Pair
Adjustable Input Level Control: 400 mV - 4V
Damping Factor: 300
DImensions: 13.4" L x 6.25" W x 1.7" H
Amplifier Specifications:
Number of Channels 1 - Mono
RMS Power (4 ohms) 300 watts x 1 chan.
RMS Power (2 ohms) 600 watts x 1 chan.
RMS Power (1 ohm) 1100 watts x 1 chan.
Bridged RMS Power Not Bridgeable
Peak Power Output 2200 watts
Min. Impedance Unbridged 1 Ohm
Min. Impedance Bridged Not Bridgeable
THD @ Rated RMS Power 0.75%
Speaker Level Inputs No
Amp Preamp Outputs Yes - 1 Pair
Built-in Crossover LPF(50 - 250 Hz), Subsonic(20 - 50 Hz)
Bass Boost 0 - 18 dB
Signal-to-Noise Ratio 95 dB
Fan Cooled N/A
Fuse Rating 40A x 2
