memphis mojo 4k watts
I'll trade you my Stetsom 2k6d. It'll do 3kw @ 2 ohm, 3.5kw+ at lower ohms, and it's not such a current hog. I have a stock alt, rear batt, and front batt, and it does fine.
good deal
That would be the most ungodly trade of a lifetime.
ya mojo 4kw for an hk 2000d + 80 bucks is silly crack smoke folk talk
think id begettin screwed? im just a huge fan of ma amps, how but some 1/0 gauge wire too?
refer to previous statement.
I'm just saying a Memphis Mojo 4kw is worth **** near 3 times as much as a HK2000, so $80 hardly makes it fair. But I'm not gonna stomp all over the deal of a lifetime for the other guy, I'd do it in a heartbeat as well if I had a HK2000. I might buy you one brand new to trade plus $100 because I'd still be saving money.
oh true, my friend has two of the sundown 1500.1 amps, theyre good n i actually had one on my sub right after the orion went retarded n before he hooked up both the amps, but i can trade staight up if you include some 1/0 wire n a battery
thing in the 2kw-2.5kw range should be good for you. you'll want to do 1/0, big 3, and a yellowtop in the back. stock battery and stock alty for now, upgrade those later. zenon boards are legit, but make sure you're getting at least $600 worth of merchandise if you part out with the mojo 4kw
jcgtpafl
Registered User
jcgtpafl
tampa
BassAddictJ
AJ (ACE)
    Jun 28, 2026
