Memphis mcd 1000d question...please help
maritoze
Jedi Master
340
CA
I have one Memphis mcd1000d right now, and I plan on getting one more. I am going to be getting my 12's soon. If i want to run the subs at 1 ohm would i just buy dvc2ohm subs and wire each sub to an amp, or do I get dvc4ohm subs and somehow combine the amps...and if the second option were the case, how would I do so?
If you want to run the subs at 1 ohm you would have to only use 1 amp using 2ohm subs ran parallel. But if you're getting another amp then run 1 sub per amp and get 2 ohm subs. You'd be running your amps at 2 ohms but the power will be significantly more powerful if you have an amp on each sub.
//content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif
your first option is perfect, unless youre able to clamp those amps but im highly doubting it.
maritoze
Jedi Master
maritoze
CA
peterweiner
Mike Mccabe
