Sold Memphis mc3004 4 ch. amp
RJ_22
NC
Looking to sell my beloved 4 ch. memphis amp.....no problems whatsoever, just looking to sell because I want a 5 ch. amp to run my system. And since its a 5 ch., I have no use for this amp. Light scratches, nothing major. Pics available, just gotta charge the camera. This is the 2007 amp btw. Specs are:
# Full MOSFET Design
# Built-In Fully Variable High/Low Pass Crossovers
# User Selectable 12dB or 18dB Per Octave Crossover Slope
# RCA Bypass Output
# Platinum Finish Wire Connections
# Accepts 4 Gauge Power and Ground Wire
# 4-Channel MClass Series Amplifier
# Compact Aluminum Chassis with Custon Black Pearl Finish
# Gold Plated RCA Connectors
# Fully Variable Crossover: HP/LP (40 Hz - 6 kHz)
# 4-Way Protection Circuitry
# Optional Wired Remote Gain Control
# Adjustable Input Sensitivity: 250mV - 5V
# Dimensions: 18.5" L x 7.6" W x 2.4" H
# Number of Channels 4
# RMS Power (4 ohms) 75 watts x 4 chan.
# RMS Power (2 ohms) 115 watts x 4 chan.
# RMS Power (1 ohm) Not Stable
# Bridged RMS Power 230 watts x 2 chan.
# Peak Power Output 920 watts approx.
# Min. Impedance Unbridged 2 ohms
# Min. Impedance Bridged 4 ohms
# THD @ Rated RMS Power 0.03%
# Built-in Crossover HP (40 Hz - 6 kHz), LP (40 Hz - 6 kHz)
# Signal-to-Noise Ratio 92 dB
# Fuse Rating 25A x 2
Looking to get 200 plus shipping, plus 3% pp fees
i gotcha, give me until tomorrow morning. as for references, must of the stuff I do is local. Last thing was a d3 that i sold up here to 96MaxGle. I'll look some up though for you. the pics will be with my sn, but it is hooked up in my car, so it will be the best pics possible.
pics.....sorry not the best, but the amp is hooked up and it's hard to get a good angle on it without taking the wires out.
RJ_22
RJ_22
NC
gsa1
