Memphis Big Belle 16.ST1300D Help
stocker08
Not drunk anymore
I just recieved my memphis big belle. It is the older early 2000 model with the emblem in top right corner of the amp. I am having some problems with it unfortunetly. I bridged the front and rear channels to run my PPI355cs comps. Left comp on the front channels, Right comp on the rear channels. My left comp runs fine but the right comp doesn't. It sounds like the tweeter is playing but the mid doesn't seem to be putting anything out. I can faintly hear sound coming from it. I am having the same problem with my sub. I have it wired to 2-ohm and I can hear sound coming from it, but it is very faint.
Anyone have any ideas? I could only find the manual for the newer version of the amp. Same specs as this one. It suggests that if the light is green on the amp, then all channels should be performing well.
Well it seems to be an rca problem. I switched the rcas on the amp from front to rear and now its my right speakers that play. Afterwards, I switched the rcas in the back of the head unit. Again, the speakers switched. So it seems like the problem is the head units rear rca outputs.....my head unit is an alpine cda-9835. Any ideas? Can the belle run in two-channel mode with a single set of rcas?
stocker08
Not drunk anymore
stocker08
Minnesota
stocker08
