memphis amp and dual sub help!!
daddyden216
4
ohio
ok i have a memphis 16-MC2004 amplifer and dual xinbp212 subs. the amp is a 4 channel amp and the subs are already bridged to 4ohm with the factory box so how should i wire these subs and amp? i appreciate all the help!
MClass Class AB
Memphis Amp (16-MC2004)
RMS Power 4ohm 50 x 4
RMS Power 2ohm 75 x 4
THD 2/4ohm 0.03%
Frequency Response +/- 1dB 10Hz-50KHz
dual xinbp212
Car Speaker Type ~ Component
Elements ~ 1-Way
Nominal Power Handling ~ 600 Watt RMS
Peak Power Handling ~ 1100 Watt
Frequency Response ~ 25 Hz - 2 kHz
Sensitivity ~ 89 dB
Impedance ~ 4 ohm (Dual Coil)
daddyden216
daddyden216
ohio
MisterGrubbs
