using that amp at 2 ohms (1.8ohm dcr) is a waste. It needs 1 ohm (.7ohm dcr) to shine.
300 amp alty
1 pos and 1 neg run of 1/0 front to back. more runs the better
decent front bat, at least 3000 crank amps worth of back bats, more the better
any voltage drop under 11.5v will likely blow the amp. watch your voltage carefully.
i would sell it and get something that will run 4kw at 2 ohms if you cant change out the subs. Otherwise I'd say it the mojo at .5ohm. only way that will work is if you have at least a 300amp alty, and about 4000-5000 crank amps of bats if not more. If you can keep it above 13v, you can probably run it at .5ohm daily, but if you dont give it the juice itll fry.
