.7ohm DCR is the same as 1ohm nominal. i run mine at that and it's fine. even if you're doing a solid 12v full tilt it'll still get warm possibly hot. make sure it has good ventilation if you're under 13v. definitly need a decent electrical to run it. i'd recommend at LEAST 2 decent bats, an HO alty, and dedicated negative power runs to be safe, you CAN do it with less but itll put alot stress on the electrical and the amp. these blow around 10.5v ish volts typically.
i've heard they'll do .5 ohm (.35ohm DCR) for burps and bassrace style applications, however you need higher voltage to do it safely. from what ive heard you'll want at least 16v for that, but they spit out quite a bit of power //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i will add this is one bad *** mother ****ing amp. when you give it the current, itll deliver
