Memphis 16-ST1500d Monoblock Amplifer!
Shinju
Seattle
Memphis 16-ST1500d
Been sitting on this but I dont think I am ever going to use it, I got this local from the original owner, it is in 9/10 condition and works perfect.
This amp has TONS of power its rated at 1500rms at 2ohm mono but bench tests have put it in the 1800+ range at 14v 2ohm. this amp will not do .5 or 1ohm or 1.5 its 2ohm stable period.
I would suggest having a big 3 and either an aftermarket batt or an extra one, This amp pulls some serious current at 2ohm if you plan on running it at 4ohm you should be good with just a big 3 and stock electrical.
Specs:
Studio Series
1 x 750W @ 4 ohms (0.75% THD)
1 x 1500W @ 2 ohms (1% THD)
S/N Ratio: >100dB
Freq. Response: 10Hz 650Hz (± 1dB)
Efficiency: 90%
Fuse: 5 x 30A
Dimensions: 19" x 6.5" x 2" (48.3cm x 16.5cm x 5.1cm)
350.00 shipped obo
what appears to be scraches on the amp are not they are finger smudges and reflections from the light in the room.
gut shots taken from Ampguts, My amp has never been opened.
9570d1300339852-memphis-16-st1500d-19dfa7c40cd3999deb9936a5ca03dee9-jpg
lol I gots the ST-163004, ST-161000d and a MC-162004!
Thanks for the bumpage! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
  • Locked
Oh, just for future reference. Put $800 OBO, or you will only get that $600, or less. ;)
https://caraudiobargain.com/audio-apex-cab-22-car-amplifier-monoblock-2200-watts-rms/ Since these are back in stock they're really hard to beat...
And the most important thing you've learned in life up to this point is to get offended on behalf of other people on the internet in the attempt...
18
5K
So recently I bought a Memphis prx1000.1 and installed it to 2 rockfordfosgate r1s'. Both svc and 150rms 4ohm. I wired them to a 2ohm load to the...
Shinju
Shinju
Seattle
Shinju
