For sale is a Memphis 16-MC600D 5 channel amplilfier
Power Specifications - Full Range Channels
RMS Power @ [4 ohms 55 watts x 4 chan.] + 100 watts x 1 chan.
RMS Power @ [2 ohms 75 watts x 4 chan.] + 200 watts x 1 chan.
RMS Power @ [1 ohm Not Stable] + 400 watts x 1 chan.
Bridged RMS Power [150 watts x 2 chan. (Chan. 1-4)], Not Bridgeable (Chan. 5)
Peak Power Output 1400 watts
Amplifier Specifications:
Number of Channels 5
Minimum Impedance Unbridged 2 ohms (Chan. 1 - 4), 1 ohm (Chan. 5)
Minimum Impedance Bridged 4 Ohms (Chan 1 - 4), Not Bridgeable (Chan. 5)
THD at Rated RMS Power 0.03%
Speaker Level Inputs No
Preamp Outputs No
Signal-to-Noise Ratio 92 dB (Chan 1-4), 95 dB (Chan. 5)
Fan Cooled No
Fuse Rating 25A x 3
Here is a link to the Memphis 16-MCH600 manual if you want. I emailed Memphis asking for a manual for the amp on sale and they said that they do not have a digital copy, but the 16-MCH600 has the same circuit board and same functions, but just has updated body.
Cosmetic: There's a little damage to three of the fins on top of the amp. (Shown in pictures below) There is a scrape on the bottom left hand corner of the top also shown in the pictures below. Bottom plate that shields the amp guts has two scratches on it also shown below. And also the normal minor scratches you expect to see from a classic amp.
I had the amp tested at a local audio shop. They set up a signal generator on channels 1-4 and got output, but it hasn't been hooked up on car speakers. They couldn't test the sub channel because their test tone speakers wouldn't play that low, but I hooked it up to a JL 12w6 at 2 ohms on the sub channel by itself and it sounded really good.
So, I can verify 100% the sub channel works amazingly, but haven't had personal experience setting up components to the 4 channels and setting the adjustments, but it did pass a tone to a test speaker when hooked up to power supply and signal generator.
$220 Shipped to 48 states
I'll cover shipping. This is my first time listing anything on the classifieds, so let me know if I'm missing anything. I looked over the rules, but just in case //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Preamp Outputs No
Fan Cooled No
Fuse Rating 25A x 3
