Melodic Acoustic Intimid8rs 8" midbass/midrange drivers
BNIB I opened the one for pics. They have never seen power.
Specifications:
Recommended usable range: 40hz – 1800hz @ 24dbs
Power handling without high-pass crossover: 90 watts rms
Power handling at recommend crossover point: 200 watts rms
Impedance: 4 ohms
Re: 3.79 Ohms
Fs: 58.2Hz
Le: .74 mh
Qms: 10.35
Qes: .53
Qts: .51
Linear Xmax: 3mm +/-
Xmax Mechanical Limit: 6mm +/-
BL: 7.64
Sd: 214.1 cm2
Cms: .335 mm/N
Mms: 22.4 grams
Vas: 21.8 Liters
Sensitivity: 91 (1w/1m)
Sensitivity2: 94.3 (2.83/1m)
Coil Diameter: 2”
Overall Diameter: 8.24” (209.2mm)
Cutout Diameter: 7.13” (181.1mm)
Mounting Depth: 3.6” (92mm)
Net Weight: 6.7 lbs (3kg)
$300 obo No Trades
On me. Only for 48 states.
Specifications:
Impedance: 4 ohms
Re: 3.79 Ohms
Fs: 58.2Hz
Le: .74 mh
Qms: 10.35
Qes: .53
Qts: .51
BL: 7.64
Sd: 214.1 cm2
Cms: .335 mm/N
Mms: 22.4 grams
Vas: 21.8 Liters
Coil Diameter: 2”
$300 obo No Trades
