mechanics
treadburner
any mechanics online right now?
im in need of some slight help asap
a friend broke some lug studs off his car
we took the break caliber, rotor and the nut on the axel off.
but i cant seem to get the piece that the studs go into off for anything
no cotter pins or screws holding it in at this point either
What kind of car?
I stripped one of the studs out on my 97 Grand Am, with the wheel taken off, I just beat the stud with a hammer. It seems like it's solid, but it's just a bolt and pops out the back.
I had to get a little creative trying to get the old one out and the new one in, but if you rotate the.....whatever it's called, where the studs are mounted, you can probably find a spot to just slide it in.
94 buick regal
its front wheel drive so i cant rotate that thing at all since its the whole axle rotating
we tried beating it with hammers and everything but cant get it to budge
94 buick regalits front wheel drive so i cant rotate that thing at all since its the whole axle rotating
Since when? jack it up and it should rotate just fine....the one I stripped out was on the front of a front wheel drive car as well //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
treadburner
treadburner
st louis, mo
JuicyJeff
