Meca S1 Question
you can get it to last a few seconds more than you'd expect on that fuse, depending on the fusing methodology you choose. If anyone is interested in this, i'll go furthor into how that works.
I am! Hehe, but where to get 1/0 blade fuse holders //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
kicker //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I'm seeing this fuse holder, which does MAXI, would a blade fit?
http://cgi.ebay.com/KICKER-FHMA-1-0-OR-4-AWG-MAXI-ANL-FUSE-HOLDER-BRAND-NEW_W0QQitemZ9737309510QQcategoryZ14932QQcmdZViewItem
But ****, $37 shipped for a freaking fuse holder:crazy: !
those fuse holders are the SHIIIIIIT. I'm using 4 of those, and they will accept an ANL fuse or a MAXI fuse...they just flat out rule. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif KICKER FUSE HOLDERS FTW!
I mean would a tiny ATC fuse fit? It says it holds MAXI's, which are bigger, but I need it to hold a 25amp ATC.
What are you trying to run a 25 amp ATC for?
MECA, I'm in AS1/DB1. Currently, I'm using a 50 amp MAXI with 4 gauge. Going to upgrade my wiring to 1/0, so I'll need a 1/0 fuse holder because I want to run 2x 25 amp fuses and I can't find any 25 amp MAXIs.
Even though my current amp only has 4 gauge inputs, I'll probably upgrade in the future to something bigger which will most likely have 1/0 inputs, so I want to be safe.
Oops, I might have found some 25a MAXIs.
http://www.mouser.com/index.cfm?handler=displayproduct&lstdispproductid=646833
http://www.mouser.com/index.cfm?hand...oductid=646833
Don't bother with 25 amp ATC's, they'll ****.
Just use a pair 20 amp MAXI's instead.
Those 25 amp littelfuse ones aren't great either. Real dinky fuses (i have some).
Look for the stinger ones on ebay.
uh thats a negative ghostwriter.
I make my own fuse holders....they hold 600 MCM connections (2/0 & 4/0 compatible) and 4 MAXI style fuses.
if you look closely, thats four 25 amp fuses, which of course equals to 100 amps of fusing...the more path ways for the current to be fused with, the more surface area is naturally cooled by ambient air meaning four 25 amp fuses last a bit longer than one 100 amp fuse wired exactly the same way. This is how you get extra 10ths in DB's at competition.
Snoopdan FTW!!! //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
thx for the good information guys, its always good to learn stuff like this everyday.
loud1988honda
loud1988honda
Alabama
snoopdan
Mike Mccabe
