MDF How thick?
So if I built a 1.2 cutft ported enclosure for a type r 10 to fit in the middle compartment hole in the back of a zo6 would I be fine using 1/2"? The box would fit pretty much snug so I doubt it would flex and its a sq based install so max output isnt the goal.
The sub is a 10" and the box will be about .6 cu/ft.
Will be running about 400 RMS to it, may get some 1/4 sheets of 3/4...should do the trick. Should be no larger than 10x10x10.
I6pwr
I6pwr
Manassas, VA
eric12421
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
