mr b
Hey all I am new here but been around audio for a while. I picked up a US Amps MD2D but have decided to go with a smaller amp. So I'm considering selling it. Any input as for a reasonable price would be much appreciated.
Here are the specs:
1500W RMS x 1 @ 1 Ohms but other forums show posts where actual output is close to 1900 watts at 1 Ohm.
1000W RMS x 1 @ 2 Ohms
550W RMS x 1 @ 4 Ohms
S/N Ratio: 80dB
THD: >.09%
Damping Factor: > 100
Frequency Response: 20Hz - 250Hz
Variable Crossover Control: 40Hz - 250Hz, 24dB/Octave, Butterworth
Variable Bass EQ: 30dB Boost @ 45Hz
Subsonic Filter: 15 Hz - 40 Hz, 24dB/Octave
Low Level RCA Input
1 Gauge Power Inputs
8 to 18 Gauge Speaker Outputs
Power and Protect Indicators
Class D
Dimensions: 2-1/2"H x 10-1/2"W x 18-1/4"L
Works perfect, but has scratches on the top. Pictures to come. Only issue is that the red and white rings on the input rca's are gone. This does not affect the performance whatsoever. But hey it is what it is.
Here are the specs:
S/N Ratio: 80dB
THD: >.09%
Low Level RCA Input
Class D
