MAXXX Power you can feed KICKER l7's!
im just new bro my bad, thats why im asking for help
since your new. i would start out with like 2 12" CVR's and maybe PG600.1 an go from there. with what little knowledge you have, you dont need to run a 4k system as your first. i would bet that 98% of the people started out with systems like the one i mentioned b4 getting to where they are now. so you should read up on a lot of stuff, search things then after that, you can move on up with the big boiz:up2somet:
or wait would 1 TEAM RF 15" Be louder then the 2 l7's with the same amount of power i heard they get crazy loud.
More than likely no, but we cannot predict it... Just take some time, read around, and research more. You have a bit to learn...
Ok...when are people going to learn. Putting a large amp on a stock charging system is DANGEROUS That amp doesnt have a switch on it to tell it that its on a weak electrical system. Its going to try and pull a large amount of current. Eventually you will either...Catch your car on fire, from frying wiring somewhere (wether it be the stock wiring or your audio wiring). Or burning up the alternator.
I beg to differ. I've ran 3kw on my stock charging system for months with no problems. I always blast my music and I've yet to have a problem.
I've never heard of a car catching on fire before though because of a large amp. I also have never heard of an alt burning up (maybe you have, but I haven't). I still haven't burned mine up and believe me, I've tried.
Also, provided he uses 1/0 wiring, I'm almost 99.9% certain it WILL NOT burn up. The only way I see the wiring melting and causing a fire is either if it was TOO small (and I mean by a large margin) or if there's a short. If there was a short, the battery would be drained before enough heat would build up to melt the wire (provided he uses large enough wire). Oh yeah, I forgot to mention, fuses ain't for nothing.
Now it's a different story if he's got a Scott Owen's battery bank. . .
HardCoreSound
Wide Reciever Brap
HardCoreSound
Terrel Owens look alike
HardCoreSound
