So i'm thinking of fitting a bigger sub into an oem sub enclosure but i will need around a 2" spacer around the sub since its pretty deep, i figure 3 pieces of 0.75" mdf glued together should do the trick. Yes, no, dumb idea?
Also what should i use to seal any large gaps, spray foam or silicon sealant?
