I bought with the intent for it to run my 5200. Going a different way now. I paid $350. Letting it go for $300. Is in excellent shape 9.5-10. Bought it from shollowfu on here. This thing puts out some current.
Here's the specs.
HK-802SX:
4400W RMS 2-Channel High Current Amplifier
500W RMS x 2 @ 4 Ohms Stereo
800W RMS x 2 @ 2 Ohms Stereo
1400W RMS x 2 @ 1 Ohm Stereo
2200W RMS x 2 @ 0.5 Ohm Stereo
4400W RMS x 1 @ 1 Ohm Bridged
Digital LCD Display (Voltage, Temperature & Output Level)
Platinum Plated Connections
Quiet Fan Cooling System
High Quality Power & Protection LED’s
Thermal / Short / Overload Protection Circuitry
0-18 dB Variable Bass Boost
40-250Hz Variable High Pass Crossover
40-250Hz Variable Low Pass Crossover
Remote Bass Control
THD @ 4 Ohm
THD @ 2 Ohm
THD @ 1 Ohm
S/N Ratio: >90dB
Channel Separation: 60dB
Frequency Response: 20-20kHz
Input Voltage Range: 200mV - 8V
Input Impedance: 10k Ohms
Dimensions: 2.7" H x 12.4" W x 27.3" L
Here are some picks. Dropped it in my Focus to check that it worked. Driving 1 OEM10 at 2ohms. Rocked the 10s world!!
Here's the specs.
HK-802SX:
Remote Bass Control
THD @ 4 Ohm
THD @ 2 Ohm
THD @ 1 Ohm
S/N Ratio: >90dB
