Massive DMX barely moves...thinking DP or 2 12"s
Looney_Tune
F**k How You Feel
I have a 15" massive dmx on a rd 2200.1 bout 1700wrms...The sub doesnt really move that much. My 15" SX of a bx1500D got decently louder. Is it because I was powering closer to the rms rating? The DMXs rms is 3000w...
If this is the case then I may get a 15" Death Penalty. Should I hear a big difference from the DMX setup because it is closer too the rms...
I May also just go with 2 12" Massive CWs or Matrix Elites.
THANKS
THANKS
actually the music rms is 1500 watts for a Stage2, they rate it at 3000w for burps
It might not have much low-end if it's that stiff... could just be how the sub is //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Off a 20.1 my dmx 12 moved quite a bit....
and of the 3250.1 it toasted it within 2min or so
i wasnt very happy with the DMX either way maybe get a new sub & amp?
my buddy smoked his to, but not that bad, they still play and he still uses them but his car got all stinky.
idk whats wrong with his install but he couldn't break a 140 on the tl with 2 of them on two massive 3000 watts amps in an expidition.
the dmx's are very very stiff.
ok. Im not getting much air movement from it...which why it is for sale. Cant afford to feed it, gotta let it go. Its for sale BTW.
What would u rec off 1500w.?
2 12" matrix Elites ported
1 15" Death Penalty ported
2 15" Custom REs...600wrms each sealed
Which should sound the loudest?
whats the RE's?
I'm starting to live by RD it seems , after hearing two Classics on an rD 1000.1 and three alpha 15's on a 3250...
My vote is for
Two RD Alphas(even the V1's) on the 2200.1 at 1ohm
And why are you saying you are only getting 1700w rms out of that amp? That amp will do better than 2200 at 1ohm rms
I think you'd be very happy with two of the Alpha 15's on that amp :)
My vote is for
This is the older 2200.1 this is the Medellin 2.2k two totally different amps //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Looney_Tune
F**k How You Feel
Looney_Tune
Killeen,TX
Looney_Tune
