Making dual 12 box for trans am
  • 4
nitrousbird
First off I wanted to say whats up, I'm new to the board. Regarding my question I'm looking to build a box to mount dual 12s for my 97ta but I haven't had any expierence with sub(or pretty much all audio for that matter)and am not sure on some of the specifics. Should I let the speakers share the same space or should I split the box and have each speaker have it's own compartment? Also what kind of space should I leave for each sub in terms of volume in the box? Also where should I locate the ports and how big should I make them? Sorry if these questions seem a little lame, I'm more into performance rather than audio so I only have a pretty(extremely) basic knowledge when it comes to speakers and such.
Thanks Brad
P.S. has anyone built one for a 4th gen that can give me any tips???
well tell us what kind of subs you have and then we can help you out...you might be able to find out the box dimensions on some website but if you can't, you can just call the company and request some information...
Yes you can build a box where the subs share the same space, however when this is done, carefull attention should be paid to bracing the inside of the box so that it doesnt flex. Also if they are sharing the same space then if one goes out then the other is in danger of going out also cuz the blown sub will move with the other working one allowing it to over excursion which will lead to another blown sub if allowed to continue.
As for size, that is driver specific, there is no one size fits all. Some 12's take a small 1.0 cu. ft. sealed box while others will take a large 2.0 cu. ft sealed box. But then if you port them they will take either a really long port or a really large box to tune it low for daily driving.
Hope this helps.//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Copy CaT!
80_cutlass_mn, "Man who stands on toilet is high on pot..."
I MADE THAT UP BEFOR U DID! //content.invisioncic.com/y282845/emoticons/verymad.gif.3f39c5c2fd57527b671fad3efdfac756.gif :verymad:
!!!!ing cOpY cAt B!I!H
lol sorry man I got that from a friend who has it on his aol profile.:p
Whoa, that will be one skinny port. The width of the back wall ports will be 1.08" wide (27.5mm), but the front port will be shared by 2 subs so...
5
757
I had this same issue with my Sony. When I first got it I had speakers hooked up to the head unit without amplifiers and it worked fine. Once I...
Looks like half a dozen other makes/models on the market, rebranded . The shallow mounts look like they’re made by Pioneer but what the hay, one...
8
I think it worked .just odd bc it's brand new but I appreciate it man. haven't had any problems yet
4
Is that speaker in the existing rear deck? Are you running a sub in the trunk?Do you have that speaker on an amplifier?Are you using a stock HU...
5
nitrousbird
nitrousbird
Chitown IL
80_Cutlass_mn
SlugButter
    May 4, 2024
slater
    May 2, 2024
Latest topics
