making connections
you could use a fuse holder but replace the fuse with same size wire. the splice will generate some heat and cause additional voltage drop due to increased resistance at the splice.
you could also solder the wires together and heat shrink it. for the solder to take, you'd want a low-temp solder and butane torch.
are you saying put wire in the fuse holder?
Only because he has a fuse at the battery - his second fuse holder could have a 1/0 wire or a piece of metal rated for that ampacity. Basically, turn the fuse holder into a shunt. Wire must be rated for the fuse amperage though. on an ANL fuse holder you could put a ring terminal on each end (depending on the design).
A Shunt is another possibility if the OP ever wanted to measure actual Amps on the power wire.
http://cgi.ebay.com/SHUNT-Resistor-DC-300A-75mV-for-Current-Meter-Ammeter_W0QQitemZ250594821961QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item3a589d8749
Fuses are required, but you want as few as possible to maintain a safe electrical system. Fuses increase voltage drop to the amp, connections in general (splices included) increase voltage drop to the amp.
The above suggestion of :
Stinger 1 / 0 Gauge Power Wire Coupling Splice SPT8210 - eBay (item 310205370506 end time Mar-14-10 19:42:34 PDT)
...is correct. I was too lazy to google it myself. Thanks!
LoganSF
LoganSF
Baltimore, MD
keep_hope_alive
