I am selling a great condition Mach5 MJ18-M sub. Currently, it sits in the home theater. 140 shipped 48 states.
OD: 18 1/8 inches
ID: 16 1/2 inches
Depth from back of basket: 8 inches
Depth from top of gasket: 8 7/16 inches
Power Handling - 700 watts
Sensitivity - 94.2db (2.83 volts)
Impedance - 4 Ohm (SVC)
Recommended Box Sizes
Sealed - 93 litres (3.3 cu. ft.)
Ported - 142 litres (5 cu. ft.) 30Hz tuning
EBS - 283 litres (10 cu. ft.) 18Hz tuning
T/S Parameters
Fs = 24 Hz
Re = 3.6 Ohms
Qes = 0.37
Qms = 5.59
Qts = 0.36
Mms = 316.6 g
Rms = 8.5 kg/s
Cms = 0.14 mm/N
VAS = 210 litres
Sd = 1029.2 cm2
BL = 21.3
Xmax = 15 mm
Excellent for home audio, home theatre and car audio applications
3" single high temperature voice coil
Thick pulp cone with heavy foam surround
Double stacked motor
Vented pole
OD: 18 1/8 inches
ID: 16 1/2 inches
T/S Parameters
Fs = 24 Hz
Re = 3.6 Ohms
Qes = 0.37
Qms = 5.59
Qts = 0.36
Mms = 316.6 g
Rms = 8.5 kg/s
Cms = 0.14 mm/N
VAS = 210 litres
Sd = 1029.2 cm2
BL = 21.3
Xmax = 15 mm
Vented pole
