MA Audio HK401SX or Hifonics BXi 1606D or Autotek SS1900.1
kaimana
Hawaii Stand Up!!!!!
Code:
 MA Audio HK401SX
# 1800W RMS 1 Channel High Current Amplifier
# 500W RMS x 1 Ohms @ 4 Ohm Mono
# 650W RMS x 1 Ohms @ 2 Ohm Mono
# 1200W RMS x 1 Ohm @ 1 Ohm Mono
# 1800W RMS x 1 Ohm @ 0.5 Ohm Mono
# Digital LCD Display (Voltage, Temperature & Output Level)
# Platinum Plated Connections
# Quiet Fan Cooling System
# High Quality Power & Protection LED’s
# Thermal / Short / Overload Protection Circuitry
# 0-18 dB Variable Bass Boost
# 40-250Hz Variable High Pass Crossover
# 40-250Hz Variable Low Pass Crossover
# 24dB Subsonic Filter
# Remote Bass Control
# THD @ 4 Ohms <0.05%
# THD @ 2 Ohms <0.1%
# THD @ 1 Ohm <1.0%
# S/N Ratio: >90dB
# Channel Separation: 60dB
# Frequency Response: 20-20kHz
# Input Voltage Range: 200mV - 8V
# Input Impedance: 10k Ohms
# Dimensions: 2.7" H x 12.4" W x 10.6"
Code:
Hifonics BXi 1606D
# 1-Channel Mono-Block Operation
# 1100 watts RMS x 1 chan. @ 2 Ohms / 1600 watts RMS x 1 chan. @ 1 Ohm
# Super D-Class Topography
# Ultra-Fi MOSFET Outputs
# Illuminated Hifonics Logo
# PMW MOSFET EXVP (Exponential Vari-Power Supply)
# SPC Twin Turbo-Torroids with Simpatico Coil Design
# Fully Adjustable Accu Cross
# Crossover Includes:
   * 24 dB Subsonic Filter (Adjusts 15 Hz - 50 Hz)
# Bass Boost: Variable Bass Equalization (+18 dB @ 45 Hz)
# Remote Bass Control Included
# Balanced Line Inputs with Optional Hifonics MM-BLD-1
# Gold RCA Line Outputs
# Permits Amplifier Daisy-Chaining
# 4 Gauge Power Connectors
# Dimensions: 13.77"L x 10.39"W x 2.63"H
Code:
Autotek SS1900.1
1000-Watts RMSx1 @4 ohms
1500-Watts RMSx1 @2 ohms
1900-Watts RMSx1 @1 ohm
Which one would be better to power my 2 15" XLs..dual 4 ohms....600 watts rms but i know they can take way more with ease....not sure if they could handle the Autotek though since i keep hearing that they actually put out around 2.3k watts.....but i guess i could always just keep the gain down....
kaimana
kaimana
Hilo,HI
djman37
