Sold MA audio HK401SX $250 shipped
This is a high current draw. If you wire it at .5 ohm. its going to be a hog. If you wire it at 1 ohm and higher, it generally doesnt have a problem. I had 2 batteries and had it wired at .5 ohm. aslong as the yellow top in the cab was fully charged I didnt have a problem with dimming headlights... it stayed at 14.5v MA has i believe 3 amps that wire down to .5 ohm. They are all high current draw. This amp made my two SX's slam. SXs take 1000 watts. I was giving them roughly 800-900. ill post pics.
Off topic but i heard somethin bout the powerbass 1500.1s. That they are way underrated. a guy ran 8 diamond D3s on 1 of these 1500.1s. I got one on each BTL at 2 ohms. Which if i go by what the spec sheet says they are gettin 900 watts. Its ****ing slamming.
this ma is one of the best amp ive ever owned.
check out this ones reflection:
digital screen shows voltage and someother shit. I had it mounted so I could never read it but it lit up blue!
BIG_SUPERMAN72
mother humper
BIG_SUPERMAN72
Grand Rapids, Michigan, United States
BIG_SUPERMAN72
