Sold Ma Audio HK4000D
Tkitt21
Ok I have an MA Audio Hk4000D for sale i would like to get $350 shipped to your door this amp is in great condition and does the power.
RMS Power @ 14.4V: 50W x 1 @ 4 Ohm, 3600W x 1 @ 2 Ohm
RMS Power @ 17.0V: 75W @ 4 Ohm, 4000W @ 2 Ohm
Dimensions (W x H x D) 12.4" x 2.71" x 25.86"
Temperature, Voltage & Output Level LCD Display
Thermal, Short & Overload Protection Circuitry
Platinum Plated Screw Type RCA Jacks
Double Sided Black Epoxy PCB Board
Platinum Plated Block Terminals
Fully Unregulated Power Supply
Stainless Steel Finish Heat sink
Quiet Fan Cooling System
Remote Gain Control
Full Mosfet Circuitry
Frequency Response: 10Hz - 350Hz
24dB Low Pass Filter: 50Hz - 350Hz
24dB Subsonic Filter: 15Hz - 50Hz
Variable 0 - 18dB Bass Boost Control at 45Hz
RCA Input Sensitivity: 0.2 - 8V
Low level Input Impedance: 22K Ohms
Damping Factor: 200 @ 4 Ohm
2 Ohm Mono Stable
aren't this power hogs?
Yes they are some what. If you run them hard under the proper ohm load they will draw big time amps. If you run them easy they are not that bad. I used one at 4 ohms with only one batt stock alt never had a problem. Yes the lights dimmed a bit but not alot. Didnt even have big three done. Just keep it in mind. Just like all amps to get the power you need the power to back it up the amp.
75watts at 4 ohms. haha. tell that to usaci.
Tkitt21
Tkitt21
GreenWood, AR
Tkitt21
