Sold MA Audio HK1998 Amp, 2x Image Dynamics IDMax 10" Subs
c1rca
I am ONLY looking for cash. All prices are OBO.
2 Image Dynamics IDMax 10" Dual 2 ohm Subwoofers...$200 Each
MSRP:$399.99
Frequency Response: 20-250 Hz
Recommended RMS Power: 1000W
Peak Power Handling: 1800W
Impedance: dual 2 ohms
Ultra Long Excursion: Over 2" Linear
Bifilar Edge-Wound Voice Coil
IMPROVED! Patent-Pending RaDiaToR Cooling System
Unique Parabolic EPDM Rubber Surround
Maximized Piston Area
Inverted Dust Cap with Embossed Logo
Structural Cored Sandwich Composite Cone
Proprietary Powder Coated Alloy Basket
High Excursion Flat Spider with Woven Tinsel Leads
Power: 200-1000
XMax - 24.6MM
Sealed ft - 0.90
Ported ft - 1.50
MA Audio HK-1998 1200 Watt 1 Channel Amplifier...$90
RMS Power (4 ohms) 500 watts x 1 channel
RMS Power (2 ohms) 600 watts x 1 channel
RMS Power (1 ohm) 1200 watts x 1 channel
Thermal, Short & Overload Protection Circuitry
Platinum Plated Screw Type RCA Jacks
Double Sided Black Epoxy PCB Board
Variable High Pass & Low Pass Filters
Platinum Plated Block Terminals
Fully Regulated Power Supply
Stainless Steel Finish Heat sink
0-18dB Variable Bass Boost
Quiet Fan Cooling System
Full Mosfet Circuitry
2 Ohm Stereo Stable
THD:
Signal to Noise: >90dB
Dimensions: 11.81" L x 12.4" W x 2.7" H
c1rca
c1rca
houston
c1rca
