Ma Audio Hk1000d
FREAKY BEHAVIOR
anything bad about this amp? I wanna run it with my 2 type r's @ 1 ohm. what are your guy's opinions i can get this used for cheap.
MA AUDIO HK1000D 1000 WATT RMS MONO CAR AMPLIFIER AMP
* 1,000 WATT RMS MONO AMP
* 1000w RMS @ 1 Ohm
* 500w RMS @ 4 Ohm
* 800w RMS @ 2 Ohm
* 1 OHM STABLE
* Thermal, Short & Overload Protection Circuitry
* Platinum Plated RCA Jacks
* Double Sided Epoxy PCB Board
* Platinum Plated Block Terminals
* Stainless Steel Finish Heat sink
* Quiet, But Powerful Fan Cooled System Built-In
* Full Mosfet Circuitry
* Frequency Response: 10Hz - 350Hz
* 24dB Low Pass Filter @ 50Hz - 350Hz
* 24dB Subsonic Filter @ 15Hz - 50Hz
* Variable 0 - 18dB Bass Boost Control @ 45Hz
* Input Sensitivity: 0.2 - 8V
* Fuse Rating: 30A x 2
* Dimensions: 12.4" W x 2.71" H x 10.6" D
i had the HK800d and it did fair. Only stable @2ohm on mine though for rated 800rms. it would shut off after 3to4 songs in a row full tilt. But did a good job during that period. your in cooler climate than me though so you shouldnt have a problem
FREAKY BEHAVIOR
FREAKY BEHAVIOR
ORANGE COUNTY
audioarsonal
Mike Mccabe
