1. Product: MA Audio HC4002
2. Specs: • High Current,Non-Regulated Power Supply
• Double Sided PCB
• Cooling Fan (Thermal Regulated)
• 24dB Active Slope Crossover
• 18db Variable Frequency Bass Boost
• Variable Phase Shift(180 degrees)
• VU Meters
• Line Out
• Protection Status Indicator
Specifications:
• Bass Frequency Range: 45Hz to 90Hz
• Bass Boost: 0 - 18db
• Frequency Response: +- 1dB from 10Hz to 40KHz
• Signal to Noise Ratio: > 100dB
• Input Sensitivity: 100mV to 7V
• Channel separation(AT IW): > 60dB
• Damping Factor(ATIW / 50Hz): >240
• Typical Current Draw At IDLE: 1.4Amps
Stereo Power
• Into 4 Ohms @ 13.8V DC : 2 x 400W
• Into 2 Ohms @ 13.8V DC : 2 x 700W
• Into 1 Ohms @ 13.8V DC : 2 x 1200W
• Into 0.5 Ohms @ 13.8V DC : 2 x 2000W
Mono Power:
• Bridged Into 1 Ohms @ 13.8V DC : 1 x 4000W
Recommended Fuse Size:
• HC4002: 40A x 4
Dimensions:
• 2.3" x 10.8" x 26.4" (H x W x L)
3. Description/Condition: Its old but i repainted it pearl white to match my Mitsubishi 3000gt
4. Price: :$400 OBO price is negotiable.
5. Pictures:
It has some electric glue around one of the 40A fuses its not burned
• Double Sided PCB
• VU Meters
• Line Out
Specifications:
Stereo Power
Mono Power:
• HC4002: 40A x 4
Dimensions:
5. Pictures:
