MA Audio HC4002 4000 Watt 2 Channel Car Amp
Features:
High current, Non-regulated power supply.
Double sided PCB.
2x Quiet cooling fans (Thermal regulated).
24dB Active slope crossover.
18dB Variable frequency bass boost.
2x VU Meters.
Variable phase shift (180º)
Line out.
Protection status indicator.
Specifications:
Bass frequency range: 45Hz to 90Hz
Bass boost: 0 - 18dB
Frequency response: ± 1dB from 10Hz to 40Khz
Signal to noise ratio: > 100dB
Input sensitivity: 100mV to 7V
Channel separation (At 1W): > 60dB
Damping factor (At 1W / 50Hz): > 240
Typical current draw at idle: 1.4 Amps
Power output:
Into 4 Ohms @ 13.8V DC = 2 x 400 Watts
Into 2 Ohms @ 13.8V DC = 2 x 700 Watts
Into 1 Ohms @ 13.8V DC = 2 x 1200 Watts
Into 1/2 Ohms @ 13.8V DC = 2 x 2000 Watts
Bridged into 1 Ohms @ 13.8V DC = 1 x 4000 Watts
Here's a picture of the inputs:
$535 shipped or make an offer.
mockall
Features:
Double sided PCB.
2x VU Meters.
Line out.
Specifications:
Power output:
mockall
