Sidebinder
Banned
Up for sale is an m.a. audio HK-4000D Amplifier, I don't know if it works and I don't know whats wrong with it. AS-IS. I haven't used it in a long-time, it's been in storage. It is in good shape cosmetically but, needs a new digital display. When I did have it hooked up, it really slammed some 18's.
I am being very clear that I do NOT know if it works as intended or if it will need some work. I am selling it AS-IS!!
MA Audio HK4000D 4000W RMS Class X / D Competition Monoblock
2000W @ 4 Ohm
4000W @ 2 Ohm
Temperature, Voltage & Output Level LCD Display
Thermal, Short & Overload Protection Circuitry
Platinum Plated Screw Type RCA Jacks
Double Sided Black Epoxy PCB Board
Platinum Plated Block Terminals
Fully Unregulated Power Supply
Stainless Steel Finish Heat sink
Quiet Fan Cooling System
Remote Gain Control
Full Mosfet Circuitry
Frequency Response: 10Hz - 350Hz
24dB Low Pass Filter: 50Hz - 350Hz
24dB Subsonic Filter: 15Hz - 50Hz
Variable 0 - 18dB Bass Boost Control at 45Hz
RCA Input Sensitivity: 0.2 - 8V
Low level Input Impedance: 22K Ohms
Damping Factor: 200 @ 4 Ohm
2 Ohm Mono Stable
Dimensions: 12.4” W x 2.71” H x 25.86” D
2-Year Manufacturer's Warranty
$350 O.B.O.
$50 Flat-Rate or FREE Local Pick-Up is available.
2000W @ 4 Ohm
4000W @ 2 Ohm
Remote Gain Control
2 Ohm Mono Stable
$350 O.B.O.
