Lucky i seen this? Fz3800 internals..
Wait...a...minute...
The caps, right?
Sent from my LG-H631 using Tapatalk
You're completing the circuit with the volt meter. It's reading the circuit voltage the same as it would read when you touch the ends to a battery.
Ever noticed a spark when you hook an amp up? (if the battery isn't disconnected)
Yeah, it's the caps charging if I remember correctly. There is a completed circuit.
Probably pretty small. Millivolts, right?
If it's a higher voltage at the speaker terminals and you don't have speakers hooked up, the caps could be holding a high static charge and there's no load on the speaker terminals to dissipate it.
No load. Was 12.1 at the speaker outputs
OKAY
it'snotdatloud
OKAY
I.E. 951/909
OKAY
