LP/HP/Bypass?
high pass = everything over specified frequency goes through.
so that is what you want.
when you say bypass i think you mean band pass
and a band pass isnt nessecary in this case since the tweeter can play as high as your deck can output.
a band pass is a combination of a low pass and a high pass
so if you have a BP set to lp at say 3.5khz and a hp at 80hz everything between 80 and 3500hz would be passed through.
i dont know if you knew that so i just wanted to explain a bit.
but if you already knew that then nevermind //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
~Magick_Man~
tractng
tractng
Los Angeles
helotaxi
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
