Lowering Car
Depending on the car, springs, and swaybars (clearance)
If you're doing it for performance, you need new shocks, and if you don't replace those now, you'll be replacing them eventually anyways, because your factory ones will quickly wear out with a lower ride height.
Like he said here, depends on vehicle. If you replace the springs you will lower the ride height of the vehicle making you need shorter shocks.
It's a Toyota Camry.//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif Im simply doing it for looks, I don't expect to much performance out of my car lol.
I was sorta wanting to keep the stock springs just incase. Mainly curious to know if just replacing the springs will give me the look im wanting? Would I need to replace the shocks?
so when the perch gets moved down a notch, the rides height will remain the same?
Thats correct the shock will have nothing to do with the ride height, just the smoothness of the ride. The spring is what effects ride height. I have kyb adjustable shocks the only thing that lowers my car is the coilovers not the settings of the shock. Here is a link to the koni site for more infrmation http://www.koni-na.com/products.cfm
woody89
Boing Yoing
woody89
Louisville, KY
stealthcl
slater
    Oct 4, 2025
1aespinoza
    Oct 4, 2025
