I have 2 pair of Mpyre 65M Mids with passive crossovers left to sell. I may be able to get more in the future, but that's not certain at this time. To get these last sets sold, I've dropped the price to $100 a set shipped CONUS via UPS ground. If you want both sets (shipped to the same address) I'll take $190 shipped CONUS via UPS ground. Addresses that require USPS delivery will cost extra. PayPal only, no e-checks. PM if you want them.
Mpyre Audio 65M
Patented XBL^2 Motor
Fs: 35 Hz
Qms: 2.8
Qes: 0.48
Qts: 0.41
Vas: 23 liters
Re: 3.50 Ohms
Le: .005 mH
BL: 6.13 Mms: 23 grams
Sd: 140 cm^2
Cms: 0.5 mm/N
XMAX: 13mm
XMECH: 15mm
Depth: 3 1/2"
Pwr Handling: 150WRMS
Single 4 Ohm Voice Coil
Mpyre Audio 65M
Fs: 35 Hz
Qms: 2.8
Qes: 0.48
Qts: 0.41
Vas: 23 liters
Re: 3.50 Ohms
Le: .005 mH
Sd: 140 cm^2
Cms: 0.5 mm/N
XMAX: 13mm
XMECH: 15mm
Depth: 3 1/2"
Mpyre Audio 65M
Fs: 35 Hz
Qms: 2.8
Qes: 0.48
Qts: 0.41
Vas: 23 liters
Re: 3.50 Ohms
Le: .005 mH
Sd: 140 cm^2
Cms: 0.5 mm/N
XMAX: 13mm
XMECH: 15mm
Depth: 3 1/2"
Mpyre Audio 65M
Fs: 35 Hz
Qms: 2.8
Qes: 0.48
Qts: 0.41
Vas: 23 liters
Re: 3.50 Ohms
Le: .005 mH
Sd: 140 cm^2
Cms: 0.5 mm/N
XMAX: 13mm
XMECH: 15mm
Depth: 3 1/2"
