Louisiana_CRX's next SPL Beast ?????
the same style box they use in Europe in the Fiat Pandas...it won't be a daily box.....I'll put one of those together later on...
like this right:
found this surfin around...two 3512s on a z1 hitting 152.1db iirc....so you should be up there //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
and to your comment about your enclosure not being pretty...your wrangler enclosure is bad@ss!
like this right:
actually that is one of many possible Panda enclosure options.
there are much much better ones out there as well //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
just because it does a decent number in a Panda it doesnt mean it would do the same in another vehicle. You can almost be assured a similar it would do no where near the same number in another vehicle.
actually that is one of many possible Panda enclosure options.there are much much better ones out there as well //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
yes i'm full aware of that...you could have two of the same year model panda same equipment and still hit different numbers...i also saw a focus setup with one dd15 on a z1 only hit a 144.8 with a panda style enclosure...here it is (3515):
....i'm sure there is a reason they are running panda's and not focus's //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
plus the focus probably peaks different than the panda's...i've read that panda's peak at 68-70hz:wow:
that is similar to the design I'm using..I'm doing two 9512g's with 2 6" ports in the middle...I don't expect it to be as loud as a Panda...I'm just experimenting with that style box.....heck it may not even break a 150.....I'll be doing some test tomorrow...I had the box sprayed in bed liner material this evening...Hopefully there will be some new pics tomorrow evening...and hopefully I'll have a decent # to post.....
Louisiana_CRX
dem shoes......
Louisiana_CRX
Piney Hills of Louisiana
GrindFrog
