Loud horn?
save1999
I've seen these before and now I want my own. They're basically horns that are placed outside of your car that can blare deafening music. Now what sets this aside from the average Loud horn or speaker or whatever is that they play music from your mp3 player. Most I find online play 1-3 pre-set songs. My friend told me he got his horns for $10 each at the flea market but surly its not that simply. How would you connect it to your stereo? I don't know. Just need some insight I guess. Btw this will basically be for throwing parties outside, although it should not matter what they will be used for. brand-sneakers
all you have to do is go to radio shack. they have two different sizes. ones a 6" i believe and the other is a 8" and the 6 is rated 25rms w/ 8ohm and the 8 is 50rms w/ 8ohm magnet. Buy as many as you can fit under your car and wire them to a 4 channel amp. Also it is a good idea to build a kill switch for the speaker. I wired a relay into the + wire on mine and then hooked the relay to lighted switch on my dash so I can flip it on and off. I would also suggest wiring a couple of 100V capacitors in parallel on the + side of the speaker wire as well so that you cut your frequency at 200hrz so you don't bust it while your listening to rap.
I will warn you though. Having one means you will most likely end up using it to mess with random people while you drive. They are loud if you give them max power. Standing you can hear it about 500' away but driving you can still hear it in another car following someone doing 80 down the highway.
save1999
save1999
newyork
1rockford1
