Sold lots of power-40k+
defj
NY
i have 8 adassa audio 5K warlords forsale.time to go bigger.right now i am not interested in trades.$750 each,plus shipping and paypal.i can do alittle better for multi orders.These are a zenon board(just like atomic and cactus 5k).here are the specs from adassa website:
Ultra Class-D Linkable Deep Bass Mono Block Amplifier
Double Sided Through Hole Epoxy PCB
1 Ohm Stable Circuit
Daisy-Chain Through Output RCA
Two Amps Linkable Function : Output Master and Input Slave
Efficiency : 88% @ 4 ohm, at 100Hz
24dB Octave Variable Crossover
Multi-Way Protection Circuitry(Thermal/Over Current/Speaker short/Speaker DC protection)
RCA Line Input and Output
18dB Variable Bass Boost
Input Sensitivity : 200mV ~ 6V
Subsonic Filter : 10Hz ~ 60Hz
Variable Bass Boost : 0 ~ 18dB
Variable Low Pass Filter : 30Hz ~ 300Hz
Variable Phase Shift : 0 ~ 180 Degree
2 By Zero(0) Gauge Power Supply Connectors
Signal/Noise Ratio : > 90dB
Damping Factor : +350
Tested Voltage and THD : 14.4V/18.0V & Less Than 1% T.H.D.
Operating Voltage : DC 10V ~ 18V Power Input
Wired Remote Controller (Optional)
defj
defj
NY
ninjawhiteboy12
