lossless codec support via USB
Not compressed lossless (I was searching out this for flac files), but I found out this about two recent installs: a Pioneer 800PRS doesn't support *.wav through USB (I didn't pay attention to this when purchasing) and a Pioneer 700BT does support *.wav through USB (again, didn't pay attention). Nice surprise with the 700BT, and it works flawless with a WD 160GB HDD. With *.wav, a little over 200 CD's. Plenty for this cat.
Does it recognize tags on wav files? I want the artist/album/track info as well as a mini image of the album cover to show up on my screen.
Looking at the Alpine manual again it doesn't appear that they support wav files. It's a shame because those digital media receivers have the best displays.
Here what Alpine Sweden said to me a while back regarding doable formats from an iPod:
If you use the fullspeed interface on the iDA-X100 you can do any format, because you will then be using the iPods DAC, it's only when using the USB cable that restrictions occur.
I guess that will be the same with all iDA-X HUs, I can't recall?
Edit: I might add that that would mean: any format supported by an iPod, of course.
Here what Alpine Sweden said to me a while back regarding doable formats from an iPod:If you use the fullspeed interface on the iDA-X100 you can do any format, because you will then be using the iPods DAC, it's only when using the USB cable that restrictions occur.
I already knew all of that from inspecting Apline's web site. I don't want to use an iPod.
Then I fear that your options will be few, if any. I've looked at quite a few HUs, and at least, it is not a common feature. I really would like to know what the problem is, transferring lossless via USB is nothing for the audio industry, only for the HU guys?
Tywin
Tywin
Niceville, FL
buggsson
Mike Mccabe
