loop noise
what am i suppose to check on my grounds? and it shouldn't be my cd player everything is amped. it's not always just "ground" problem.
Are they secure, did you ground it to a poor location, IE did you accidentally tap into a plastic panel somewhere? Did you sand down where your amps are grounded to? Also, did you ground to a single location (if using more than 1 amp)?
Your RCAs are grounded as well, so yes it could be your HU.
And yes, the alternator whine is caused by a grounding issue.
i have a second battery gronded to a metal panel tightly then the two amps grounded to the battery but it did it before the second battery and there is two amps
I'm certain you didn't do the big 3 did you? I had the loop noise for the longest time. As soon as I upgraded the bat and alt ground wire it went away and I've spent literally days trying to figure out where it was bad from the HU grounding to amp grounding, to RCAs, etc..
Just do the big-3 and you're set. A quick test, disconnect your alt, start up the car (NOT for longer then a few secs to test out if everything works). If you still get the noise then it's something else. If the noise is gone then it's the alt.
patrick1202
patrick1202
gallatin,TN
audioarsonal
