look what fedex delivered
Crzy
so today i got my RL-p's in they are teh sexy
one question though my amp has yet to come in but can i put both subs in my box and run one sub off my kenwood 8101D at 2 ohm (d4 subs) and use the second driver as a pressure driver? would it mess stuff up? should i just wait for my
1606d to come in?
pics //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
with series /paralell wireing you mght be able to connect both subs to the kenwood, what power does the amp do at what ohms?
reason i was thinking onewas because heres power output (cant og down to 1ohm i tried it just pops fuses on the amp itself)
POWER RATINGS
- Maximum Output Power: 1000 Watts
- Power Output at 2 Ohms, at 14.4V (100Hz, 0.5% THD): 400 Watts x 1
- Power Output at 4 Ohms, at 14.4V (20Hz - 200Hz, 0.5% THD): 200 Watts x 1
i suppose you could connect 1 coil from each sub and show the amp a 2 ohm load and share 400 watts between the two drivers. but im not sure if it is bad for the sub to run only 1 coil?
i heard tha under powering a subis bad is this true? what i if i put 200 to each? be bad for them in any way less then them not being able to reach full xmax? any downsides on the coils or driver itself?
I wouldnt run a single coil on a DVC sub nor would I run only 1 sub with power with both in. you might damage the coils
underpowering subs is in no way bad, if you want to go ahead
o really? thanks for that information for some reason i thought it was bad. o well im gonna run them at 200 watts a peice for a bit untill i gte my 1606d and build an amp rack //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif ill just run them like im running my HE2's at 4 ohm with 200 to each sub.
it will be a big difference listening to themat 200 watts then jumping to 800 a peice //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Crzy
Crzy
Doylestown, PA
audioholic
pfft
    May 1, 2024
pfft
    May 1, 2024
