Look at this BEAST...
straight spl subsee the specs +12.xx @ 68.xxdb
with a 95db1w/1m
there's a lot of other stuff if tuned that high will get those numbers
I dont know much about the numbers like that //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
But that is a great efficiency.
Hmmmmm??? //content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
Looks cool but the BL is @ 8 ohms so it's not insane -- the BL^2/Re is 162 which is pretty in-line and similar to many other good quality 1.5-3k rated woofers on the market. Makes for a strong enough motor to do good numbers but not TOO strong as to impede bottom end. Actual sensitivity is also going to be 89 dB -- the 95 dB figure is taken at 2 ohms and 2.83 which is actually 4 watts. You can calculate the 89 figure using the other specs posted.
Of course those specs certainly aren't bad and based on the looks of the motor I'd say coil cooling is also quite good. Should be a nice driver all in all and does look very impressive in person.
The_Grimy_One
The_Grimy_One
Phoenix, AZ
sundownz
