lj audio 1000/1- matts 3500
ok so 2 amps and 1 sub you will be spending 1900-2100 or so if you buy new
with that kind of money you can come very close to building a full system. a very nice one
especially if you buy used
Get rid of the over priced & hyped w7 get 2 nice subs & go with a sundown amp & wang that $hit. Or just go with the mmats amp on the over hyped & price w7.
I'm running a single 13W7 (sealed) & JL 1000/1 amp and it sounds awesome, the bass is just super clean ,deep and powerful, it absolutely destroys my previous dual Kicker 12's setup, also the 13W7 manual tells you how to setup a 1000/1's various settings precisely for the 13W7 including setting the gain with a multimeter.
My younger cousin is running his 13w7 off of an old MTX 81000d @ 3 ohms and it provides plenty of bass in his Chevy Colorado extended cab!
As for power, 1000 watts RMS should be good enough... Two JL 1000/1s are OVERKILL for a single 13w7 especially since the 1000/1 will give you 1000 watts RMS between 1.5 and 4 ohms. Wire your coils in series to achieve a 3 ohm load and go with a 1000/1. If you really want to go MMATS, a D2100.05 would probably work well in your situation with both of your coils in parallel to achieve a .75 ohm load.
Dlh_tank
Dlh_tank
chipley,florida
gunz4me
