Lithium or smaller lithium plus cap
If it's from a second battery you take worst case scenario on voltage, which is about 12v. So 6000w / 12v = 500 amp continuous discharge current which should be your primary concern. There's not very many needs for caps out there, this definitely isn't one of em. Something like a SLIP40AH or equivalent would be right on target for handling the upper limits of that load without significant vdrop. If you've got a decent AGM under the hood you can probably knock a little bit off the requirements of the lithium battery.
Wedase
CarAudio.com Newbie
Wedase
Michigan
THATpurpleKUSH
vegang
vegang
