Sold Lightning Audio S4.1000.1d x 2
Shinju
Alright I am selling my Lightning Audio S4.1000.1d Amplifiers.
They are both in perfect working condition and both are 9/10 cosmedic.
They are 1000 RMS @10hm and yes they do rated power. Strapped they do 2000rms @2ohm.
I am getting my SAZ-1000d here soon so I will have no use for these.
Asking 175.00 Shipped Each they wiegh in at 23lbs each so shipping will be atleast 25 bones at UPS.
Or if you want both I'll do 300.00 + ship for 2k @ 2ohm pretty good price!
I am using one in my xB right now on 4 E8's and the other one is sitting in my Office.
I will also have the matching S4.400.2 up for sale too!
Amplifier spec's
CEA-2006 Compliant Yes
Number of Channels 1
Rated Power 250 Watts x 1 @ 4-Ohms
500 Watts x 1 @ 2-Ohms
1000 Watts x 1 @ 1-Ohm
2 Amplifiers Strapped Together
1000 Watts x 1 @ 4-Ohms
2000 Watts x 1 @ 2-Ohms
Total Power 1000 Watts
Max Power
Bridgeable Yes (using 2 S4.1000.1D amplifiers)
Crossover Controls 12dB/octave Low-Pass only
Tone Controls Subsonic Filter
Variable from 15Hz - 40Hz
Signal Input Low Level (RCA): 100mV - 5V
Slave In: (1) RCA @ 100mV - 5V
Signal Output Master Out: (1) RCA
Power Input Connector Block Terminal
Power Wire Gauge 1/0 AWG
Speaker Output Connector Block Terminal
Speaker Wire Gauge 8 AWG
Heat Sink Type Extruded Aluminum
Cooling Convection
Remote Control Remote Level Control
Visual Indicators Combination Power / Protect
Circuit Topology Class Class D
Frequency Response 10Hz - 250Hz
Signal-to-Noise Ratio >70dB A-weighted
Channel Separation 50dB
Fuse Value (3) 30 Amp
Dimensions 2.0" H x 10.5" W x 15.75" L
(5.06cm x 26.67cm x 40cm)
Shipping Weight
Kit Includes Allen Wrenches
Mounting Screws
Replacement Fuses
Nice amps, I wanted one of these a while back...
Thanks!
They are here if you decide to snag one up. Out of all the 1000w RMS rated amplifiers I have played with for its price tag... Well worth the money the one I am running hardly breaks a sweat at Full Tilt when showing of the E8's
They are power hungery though! NO less then 4guage wire, Optimal is 1/0
These are back up for sale, ccook052381 canceled his E-check with out contacting me or any warning.
Payment From christopher cook Mar. 8, 2009 Canceled on Mar. 10,2009 Details $325.00
/Bump for some Solid Power!
Shinju
Shinju
Seattle
Shinju
