LEts Try this again!!!!
SunKicker
OK, few days ago I asked a question which no one seemed to REPLY, however I have my sub wired correctly it's a DVC 2ohm Kicker Comp vr, I hook it up + to + - to- at the amp I get nothing, yet I hooked it backwards and works no problem, and the subs itself is wired corectly what's causing this?
thanks
Originally posted by SunKicker OK, few days ago I asked a question which no one seemed to REPLY, however I have my sub wired correctly it's a DVC 2ohm Kicker Comp vr, I hook it up + to + - to- at the amp I get nothing, yet I hooked it backwards and works no problem, and the subs itself is wired corectly what's causing this?
thanks
how are the vc's wired? paralell or series? The sub should actully work both stadard and with reveresed polarity, so chances are there is a fault in your wiring, never hurts to just remove it all and re do it.
I did take it out and re-do it, it's all correct inside the sub it's dual 2ohm, runnint it at 4ohm load, I have 2 of these subs and the other is fine.
SunKicker
SunKicker
London
SunKicker
