why would you get double the power to power woofers that are only rated for a certain power...
if at your peak you get rise up to 2x or 3x great, that is you most efficient frequency and it will be loud with little power, but the second a different note plays you could very well be putting double power to your woofers.
by getting a amp double the rms of the woofer you could only hope for a 3db gain, IF you box was built properly to utilize the power for that woofer properly. most people that double power to a setup that is already working relatively efficiently gain a little over 1db.
just look at clamp results, generally the woofer rated for 600rms will be loudest on 600rms. once you start nearing the next woofer tier the 1000rms woofers will be loudest
put some power on your fvcking woofers and build the enclosure to make you happy with the power/woofer you are using. there are plenty of people doing 150 while clamping near 1k (which can be done with just about any true 1k amp)
