Lets just say.
Im talking 8 cubes after bracing, but not after port area.
I would like it tuned to 42hz. Subs are undecided.
Power used is 1700. (Rms) (oh and at 1ohm not that, that matters.)
you probably shouldn't build a ported box until you know what subs you are using. the sub more then anything decides what box ishould be used.
like "what condiments should i use for a undecided meal"
I am deciding on 2 different ones. and I know the box size is the same and the tuning off it will be almost the same.
So since the box is 80% of the install I already built a 8 cube box. (dont remember the demensions) and now i look at it and am like **** IT lets put in some areoports.
So how many at what size would make a 8 cube box (before port area) tuned to 42 hz.
Vicodin113
Ms Peachez FTW
Vicodin113
NYC
Vicodin113
